hey I have this a/c charger I got from wal mart to see if it will my A/C work, the thing is I cant find the place where to spray it in. It says its between the dash and compresser but I see it but it doesnt latch on right like it is too smal. Than I see a big port near the radiator it looks like it can spray in there but i dont think it goes there. Does anyboyd know exactly where to spray this stuff in? Its a/c Charger
Charging A/c
The 90-93 Accord is based on R12 coolant. The crap you buy at wal-mart is R134 coolant. You need to buy the "retrofit" kit that allows you to use R134 on an R12 system. Basically, it is an adapter for your valves, and adds some fluid into your compressor system.
I repeat, you need a "retrofit" kit before you can use Wal-Mart recharging kits. Retrofit kits come with everything for a recharge too, so save those wal-mart cans for next year.
My a/c is not working, and I was thinking it needs to be rechaged..however, I see a sticker (stock) warning of r12. Then I see a sticker next to it that says it has a flourescent dye to test for leaks, that was placed in the car 6/29/98. I dunno wthe problem is, or what I need to do, but are you even able to put dye in r12? I thought it was a 134 thing only...
-A. SwiftCB7 member number 137
Black Doubt Crew member #2
Ebay Whore Club member #5
-I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
AIM: boostinswifty38
alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
It seems like it didnt work I noticed right when I connected the hose with the can it said full well right when I turned the noel it said full so I dont know What it can be its probably just broken. when I hit the AC button to come on is that I dont even hear it kick in like u do on other cars. Like mycar does not even get a slight bit louder any suggestions?
Uh, you're not suppose to do that either. When the system is running the pressure in the low side tends to be about half of what it is when the system is off. At least, this is what I noticed the last time I had a guage hooked up to mine.Originally posted by pwrusr
Did you try filling the system with the engine running and ac turned on?
That's what worked for me.
I remember talking to a A/C tech, he said to have the engine running and A/C on when filling the system.Originally posted by NutBucket
also check the amount your supposed to fill the system with. if I remember right it's about 25oz. check the R12 sticker to be sure how much to fill it with.
