How can you tell when your valves are bad?
bad valves
give me a picture?
check if there is excessive wear on the stem, tip or if the valve head is not round (usually mean you burnt a valve is a chunk is missing)
everything should be smooth and no nicks or excessivly deep scratches.
then with a dial caliper or micrometer you can check valve stem thickness, the margin and finally overall valve length
