my motor today decided it was going to start to pour oil and smoke from my crank case breather (when the car is on )... im thinking my valve seals are gone or i have no idea ... the car is a 5 speed with a f22a4 with just an air intake and a gutted cat ... that car also has 200314 milles on it ...
issues i think my motor is gone !!!
the motor sounds like it always has ... oil change was over do but I've had a small oil leak for about 2 years now so i put a quart in about every 10 days on average. when it started I thought the same thing and immediately changed my oil ... when i started the car after the oil change i could smell the new oil burning and the smoke still persisted. When I drove the car home from work smoking the first time (before the oil change) it seam normal power wise and no odd noises coming from the engine compartment. I don't see any smoke out the tail pipe ether. I have not driven the car since the oil change cause the smoking is embarrassing it looks like theres some thing on fire under my hood when its closed.
The filter I'm talking about is the small hose that connects the intake pipe to the valve cover. I removed that hose because I has getting oil in my intake and installed a small filter on top on both sides.
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
I have the exact same problem, only mines is worst. I have to add a quart of oil on an average of two days. Like you, I know its leaking from the head seals. Oil is always kinda spewing out under the hood where the seal is located and it gets a little splashed on the top of my hood. My motor was already doomed from the start anywho..
my pcv is still in its stock location its the vent next to it ....Originally posted by KeelesKustomeyou need to refit your pcv valve hose to the intake because that plays a critical role in keeping the right amount of preasure in your valve chamber,, you can run it to a drain can if you want but,, thats a no no.
them if anybody has any tips or sujestions it would be greatly apreciated.
