How to Check CEL?
    How to Check CEL?
    My cars is throwing a CEL.....ok 1st start in the morning its all fine about 15 minutes later of driving the car the CEL pops on and give the car gas it bogs and wont rev past 3500..but ok my main question how do i find out why the check engine light is on..Sorry im new to this part of the car CEL and stuff =[
    i have a P28 ECU it has no light on it.
    Project EX Coupe Coming Soon...
    ..::Built not Bought::..
    Take a look at your ECU. It will be throwing a flash light.
    For example, when you have 1 long flash light and then 5 short flash lights, it means code 15 and so on.
    I've found the list for you:
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor
    65 Secondary oxygen sensor heater
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    Your car is faster, I'm the better driver
    Greetz Erwin
    My last ride
    Shakes and Fidget - The Game
      alright bro thanks for ur help running out to me car. 1 more question does the car gotta be running or anything?
        I always did it with mine. I don't know if you can read it with just the key turned.
        Greetz Erwin
        My last ride
          i have a p28 ecu does that make anything any differnt?
            cause im lookin at my old f22 PT3 ecu it has an actual thingy on the outside
              No, in this case it doesn't. Just when your looking for emission codes there are more differences.
              Greetz Erwin
              My last ride
                ok cool goin outside to see what i can find out. be back in 10 minutes
                  Ok my friend
                  Greetz Erwin
                  My last ride
                    Ok my friend
                    i can not find a light on my ecu anywhere i got it and and opened it up and i still dont see an light??
                      i found this but i dont have a light.
                        Anyone?
                          Yo ,the light is your check engine light on you cluster. You jump the wire on the pass side kick panel the one with the blue connector, turn the key and count the flash on the check engine light
                          Accord Of The Month January 09
                          Accord Of The Year 09
                          My 2 Babys
                          BMW TECH FOR 15 YEARS
                            alright thanks its code 17. So ima go to my work and get a fuel injector service and see if that works.
                              Greetz Erwin
                              My last ride
