Hey, if i hardwire both cooling fans to an ignition wire, and then to a switch, will that cause the a/c not to work because a module or something has been over ridden and over passed? thanks
Question about wiring fans to switch (help)
there are many... usually wires that are under the steering wheel column. An ignition wire, by deffenition is a wire that has power when the ignition is on, and doesnt when the ignition is off.. The other choice is a hot wire, which has power at all times. To find an ignitio wire, find a test light, hook it to a wire that has no power when the car is off, and has power when the ignition is on. hope this helps
