Need Help
    Need Help
    so i was driving on the freeway this morning and was fine, then i just lost power, i mean i was still able to run the tack up and stuff but i wasnt going anywhere, it was like my clutch gave out, as i was coasting to the side it caught and i was able to accelerate again then it slipped again. Now when i put it in gear it just runs without catching and makes a clunking noise, it gets louder when i move up in gears ie 5th is way louder than first.
    anybody have any ideas? i have a newer clutch. i changed my mtf yesterday and filled it back up and have all the plugs in. could my axle have slipped out? as random as that is. cuz im not losing fluid and everything is hooked up and runs...
    any help please i gotta go pick it up after work and would like to try and drive it home..
    Frost White CB7 Crew - Member #41
    92 ex 5spd
    ^^^ Did you fix this issue.... If so what was wrong?
    My Members Ride Thread ( Do It )
      this was a while ago but i did fix it.
      i went back later and jacked it up and got underneath. the intermediate shaft has slid out of the tranny. looks like i broke the bolts that hold the bracket. i guess i didnt put all the bolts back in when i finished my clutch. easy fix tho once i got a couple bolts
      92 ex 5spd
