H23 headgasket question
    I'm placing the h23 head on right now and I still im questioning where to plug which holes in this f23 head gasket and if this is even an f23 head gasket?
    can someone please tell me if this is all i have to do so i can finish this up tonight or atleast procede with the swap
    I think it's just pluging the four lower green circled area's so i can use this gasket I'm i correct and is that all?
    I believe, that the hole you need to plug is the lower left hole in that picture. It's pretty obvious if you put it on the h23 head.
      Im guessing here:
      put the gasket on the head. and compare with the holes on the bottom end. which ever don't match, block off.
      DEVOTE
      FS: Lokuputha's Stuff
        i put the gasket one the head and the only thing i see is the two upper holes are blocked off and those four lower holes have nothing going to them i cant tell
          in the diy it only says one hole so thats what is throwing me off
