If I bypass the EGR
    If I bypass the EGR
    with a plate will I get a cel. if so Can I simulate a correct reading or function
    depends on the ECU. which one do you have?
      p13 jdm
        p13 jdm
        yeah, it would throw a CEL. you could get a chipped p28 and it wouldn't. you'd also not have to worry about the POS knock sensor retarding the timing between 0-5500rpm (the normally cause you 3-5hp or worse).
        the p13 is actually a shitty ECU compared to the other obd1 ecu's. it's BARELY obd1 and still has a lot of the inflexible characteristics that the old obd0 ecu's had
          Well I have had a f22b2 in the car then went with an h22a and the egr plug is different so its not plugged in since I cant get to the junkyard to get a plug and figure out the wiring. The car hesitates slightly and I assume this is the issue since its my only cel. So for now I was going to make a block off plate and see if it fixes my hesitation. So if I go with a chipped p28 I can get it programed to not look for the egr.
            P28 doesnt look for an EGR.
              you just chip it to work with your engine. should be easy to find a p28 with h22a program.
              it doesn't control the IAB without an added switch (never bothered me, i ran my IAB straight to the vacuum port) but it doesn't look for a knock sensor (yay) or the EGR (yay)
                hmmmm
                my p39 didnt give me a cel
                jdm f22b
                welcome to the DOHC-side..muuuahahahahahah
                http://www.cb7tuner.com/vbb/showthread.php?t=1906
                  As long as the sensor is plugged in you will not get a CEL. Even if you have a plate between the sensor and IM. You do need to use the Accord EGR though so the plug matches up. You read the swap FAQ?
                  Gary A.K.A. Carter
                  [sig killed by photobucket]
                    ^ really?! interesting...
                    1cor10:31
                    - 92 LX coupe
                    - 96 EX wagon (sold)
                      Yep quite a bit people have done it.
                        So technically I can block off the h22 one take the one from the f22b2 and plug it in and zip tie it in the fender or something
                          yep i have a kms egr block off plate with my egr valve bolted right on top...no problems....
                          My Members Ride Thread
                            yeah mon.... did this. capped it and plugged it back in. works for me is what i meant to say
                              Yeah, I guess that would work. Most people just put it back in the original location though.
                              Gary A.K.A. Carter
