mount question
    mount question
    i am in the middle of a 5spd swap with a f22b dohc non vtec. i am having problems with the tranny mount lineing up. i tapped the two un used holes in my p2t4.
    Is that an F23 tranny? Are you using a 5th gen accord or 92-96 Prelude manual tranny mount?
    Gary A.K.A. Carter
    [sig killed by photobucket]
      mount question
      no the tranny is from a 95 accord sir. i am using a mount from my accord. the mount seams to be off by like an inch. i need some help trying to finish this damn car
        http://www.cb7tuner.com/vbb/showthread.php?t=80212
        esp 5 speed conversion mount...makes 5 speed swap alot easier.
        My Members Ride Thread
          mounts ?
          thanx for the info on esp. i left him a message. but my real question is this, i have a f22b dohc. the tranny is from a 95 sir p2t4 . so what mounts do i need to put the set up in my car? do i need the f-series or do i need the h series.the tranny only comes on accord models. i am so confused?
            You using an automatic or manual accord tranny mount?
            Either way, they won't work. You need a 94-97 Accord manual mount, or a 92-96 Prelude manual tranny mount to make it work. Then you need 3/8'' worth of spacers on the driver's side mount.
            You need the entire Accord front dogbone mount, including bracket to mount to block. Any manual Accord (90-93) rear mount with the corresponding bracket. Any CB7 driver's side mount. Now, I am not 100% sure about F22B dohc because I have never seen one out of a car, but you might need the lower part of the mount (the part that bolts right into the block) and then use the CB7 upper part.
            I am spoon feeding you here. Did you do any reading up on this before you went for it? If I were doing it I would search and make a list of what I needed.
            Gary A.K.A. Carter
              mount question
              i did do my research before getting started, they all said it would just bolt right up. i guess they were wrong. but i ordered those mounts from esp so that will make it a whole lot easier. thanx for all the info man. i really appreciate it.
