My cars exhaust smells bad, I know the cat is working because it blows a lot of water out the exhaust, somebody gave the idea that it was running rich, which im starting to agree. What can you do to fix this?
Running rich?
well.. You can find out why its running rich. If your ignition system is weak that can cause your car to run rich. So will timing thats off, bad injectors, numerous sensors, etc. Why do you think its running rich?
whats it doing? Also, " a lot of water" out the exhaut can be bad. Is your car smoking at all? What color smoke? Any check engine light?
No codes no smoke, its not leaking coolant into cylinder because my levels have never gone down, I guess it might be timing or ignition, maybe old worn out o2 sensorOriginally posted by oozingmachismo2well.. You can find out why its running rich. If your ignition system is weak that can cause your car to run rich. So will timing thats off, bad injectors, numerous sensors, etc. Why do you think its running rich?
whats it doing? Also, " a lot of water" out the exhaut can be bad. Is your car smoking at all? What color smoke? Any check engine light?wat?
