clutch pedal
    clutch pedal
    sometimes when im stopped at a red light and in first gear with my foot on the clutch, when the light goes green and i go to give gas/release the clutch, the clutch pedal just sticks to the floor...why is that? ive got plenty of fluids in my lines...is there something on the actual pedal itself that could be preventing it from comming up?
    any tips on how to prevent this from happening?
    ..[CB7][STAR]..
    MY MEMBERS RIDE THREAD
    everything is NEW!!! new lines, new master and slave cylinder!!! they've been replaced aprox 8 times EACH in the past 9 months!!!!!
    every shop i go to says "oh your master cylinder is leaking, we have to fix it" so they do...next shop i go to says "your slave cylinder is leaking, we'll need to fix that" next shop...well...you get the idea of what will come next....
    it was bled aprox 30 days ago when i took it to a shop...
    ..[CB7][STAR]..
      either aint bleeding it right or a leak in the lines
      Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
      -(B-Pillar Bar Originator)-
        i might go get new lines...again...if that fails....then i dont know...ive been wanting a rwd car for a while...this could be a good reason to get one...im tired of spending several hundred on repairs every month...
        ..[CB7][STAR]..
          make sure you bleed it properly...if you changed master cylinder/salve cylinder, and lines you dont have to worry about that unless you have a defective part...also make sure none are leaking either.
          My Members Ride Thread
