starting problems
    starting problems
    my friend has a cb9 that has a problem that i cant figure out,,,he calls me tells me my dont start ok i go i check everything solder m. relay check fuel pressure check spark found no gas in tank (bad gauge) anyways put gas starts right up no problem all of a sudden it turns off dont start back up at all crank no start heard a noise the other day from the injector box thing under the hood on driver side anyways any help is greatly appreciated thanx guys
    hey
    anybody???
      I'm pretty sure the Main relay doesn't control the injector resistor box on a cb like it does on civics.
      Right now, you have to figure out for sure if you are getting fuel. I know you said you soldered the relay. Can you hear the pump priming at all?
        hhhhmmm
        yes i do it was running good at idle and when you rev it it would sputter then all of a sudden it turned off now it wont start (crank no start)
          bump
            Check for gas, then check for spark
            wat?
              bump bump
                hey
                already checked those
                  ok... do you have gas, do you have spark?
                    yes
                      Stick a test light to the neg side of the injectors and see if they are firing. Or see if there's an overpowering smell of gas in the exhaust after trying to start it a few times.
                      If you have fuel pressure, are getting spark, but there's no sputter or even an attempt to start, chances are the injectors are not firing. Even with bad timing it would still sputter or something so I'm leaning towards injectors not firing which is going to be the cause of the ECU not getting a proper signal for a sensor (could be a bad ground or sensor) or possibly a bad ECU.
                      Any CEL codes?
                      My Accord History:
                      91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
                      -Patrick
