could that be the cause of me removing the ps pump? i know there are ps lines connected to the manual tranny. can anyone help me out?
tranny wont shift
shifters good a and i checked everything on the tranny and everythings hooked up. its just when im driving down the road it d4 it sits in 1st gear. i could manual shift it. could it be because i have a somewhat majoir vacuum leak?Originally posted by MadSpleen85Is the shifter stuck in gear or can you move the shifter but the tranny just doesnt respond? Latermiss my turbo cb7
Three possible problem I'll list them from cheapest fix to expensive fix.Originally posted by quickangel93shifters good a and i checked everything on the tranny and everythings hooked up. its just when im driving down the road it d4 it sits in 1st gear. i could manual shift it. could it be because i have a somewhat majoir vacuum leak?
1. Solenoids are bad, replace them.
2. TCM is bad
3. Tranny is bad.
That happened to me and I changed the whole tranny, so I'm not sure if it was the solenoids.MR Thread- I brought SEXY back- LOL
If it jams, force it. If it breaks, it needed replacement anyway.
Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
but i didnt change the tranny. i didnt even touch it. i replaced the head and intake mani to a f22a6 rebuild head and ported and polished a6 intake mani.Originally posted by rudy1980Three possible problem I'll list them from cheapest fix to expensive fix.
2. TCM is bad
3. Tranny is bad.
That happened to me and I changed the whole tranny, so I'm not sure if it was the solenoids.miss my turbo cb7
^^^ I mean it happened, then I changed the trannyMR Thread- I brought SEXY back- LOL
Have you bothered lookin at the TCU. There is a common problem where some resistors burn out in that thing or something. You cant pull a code out of it? Should be able to if its an auto.
Originally posted by NAiL05Have you bothered lookin at the TCU. There is a common problem where some resistors burn out in that thing or something. You cant pull a code out of it? Should be able to if its an auto.
no codes, only tps is comming up.miss my turbo cb7
Thats a major code, could have put your car in limp mode. Clear the code and see what happens.Originally posted by quickangel93no codes, only tps is comming up.MR Thread- I brought SEXY back- LOL
that...can cause some serious problems.....could cause a decline in fuel mileage....because the TPS is sending the ECU the wrong reading. ( running rich ...Irratic idling/surging..stumbling )Originally posted by quickangel93no codes, only tps is comming up.
check the resistance ( continuity ) of the TPS.
if its bad...change it...
ON THE TRANNY NOTE..
its already been stated:
in order..
* Shift Solenoids
* TCU
* Transmission
Im having a similar problem as we speak with my 92 EX auto...I have to manually shift..because the D4 light in on ( constantly lit )..and taking off in D4 is like waiting for a snail to cross the street.
RPMs ...what are the RPMs doing?
if they're raising faster than the car is picking up "speedometer" ...( torque converter or Tranny fluid or both ) is bad
EXAMPLE...you have it in D4...and its at 20mph..but the RPMs are showing 4500-5200...( BAD TORQUE CONVERTER or TRANSMISSION FLUID or both )
if they're not...and its picking up SLOWLY.. either or...or all together ( TCU...Shift Solenoids...VSS...tranny gears stripped )
so welcome aboard...Im having similar issues too!92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
