Jus wondering how u would jack the car up
    recently i hit my muffler while backin up n the things all messed up, i was jus wonderin how u would be able to look at it
    92 Accord EX-R
    Neons
    Stock Rest - Any Ideas?
    Now would be the best time to invest in a floor jack and jack stand combo.
    Jacking point locations are in front of the rear tires and behind the front tires depending on which end your dealing with. Place the stand under a suspension a-arm or other obvious sturdy point.
    Never get underneath a car supported by a jack only.
    EGR Port Cleaning http://home.comcast.net/~em-engineering/T2T013.pdf
      there's also a place under the trunk. you shouldn't be able to miss it. it's a bump (for lack of a better word :P) that comes down.
        Really...I know the place your talking about but I always thought it would cromble in if I jacked up there...
        If I jack the rear I always put the jack on the frame, right behind the gas tank, and in front of the spare tire well.
        Jay
        Hittin Switches - Draggin XhaustAlways Under Construction
          Jay
          I've used that place more then a few times. Never had a single problem.
            u can squeeze a jack under that slammed monster?? i was curious how cars that low got their oil changed. im not being sarcastic either.....do u have a pit u can drive over or what?
            Finally Up and Running. Numbers to Follow. Check my MR
              hahahaa u drive up on wooden boards and get up high then ur good
                well my floor jack doesn't even go under the car now that its lowered, and the car drive up stands definetely don't work....so maple you drive up on wood blocks then the car ramps?? also what does everyone else do when your car is lowered...i don't want to have to use the stock jack that comes with the car.
                Originally posted by fizzbob7 i think the "jdm everything" craze is funny........it's the same thing, a fad.......and an overpriced one at that
                Originally posted by uncle_el believe it or not, this forum is not about you or your post count. it's about providing relevant information and exchanging it with one another, in order to help build a community. if you don't like that, please leave.
                  u should invest on some of these. specially the two bridges
                    yea those ramps dont work for a lowered car
                      No, I just hit a few switches and my car is sittin higher than stock.
                      But back when I had coilovers, I bought a couple of 2"x8"x10' peices of wood, cut them up and made some LONG slow sloping ramps that would enable me to get the jack underneath...other ramps I wasnt able to drive on because they where too short with too much of an incline.
                      Jay
                        invest in 4 jackstands and a hydraulic jack.
                        look in owner's manual for where to jack up the car and where to set jackstands.
                          man i dun even know what those r
                          maybe a few pics would help
                          and maybe a few of a car lifted up too would help cuz i dont know anytin at all
                          92 Accord EX-R
                          Neons
                            I use a flat brick on mine then i slide the stock jack right up under there and im good 2 go.
