H23 Throttle body
    H23 Throttle body
    is this a JDM throttlebody? I got it from a REALLY GOOD friend of mine...BUT...
    Im not too familiar with these throttlebodies..
    and what im pointing at...im having a brain fart..
    BOTTOM of TB:
    TOP of TB:
    AND...
    heres the TPS side...I thought you had to DREMEL slots into the TPS bolts???? theres a STAR pattern in the bolt heads
    MR Thread:
    Bottom is where the Fast Idle valve goes, Top is where the MAP sensor goes. Its and OBDII TB. Some come with star scres some you have to dremel.
      Originally posted by bruno8747
      Bottom is where the IACV valve goes, Top is where the MAP sensor goes. Its and OBDII TB. Some come with star scres some you have to dremel.
      thanks my friend!
      I was having a brain fart ( drank too many Caribolous )
      wait...IACV is on the upper plenum on the F22 ....im
      Its and OBDII TB.
      which means..I can't use it?
      MR Thread:
        Its off some H series car...Looks OEM. The FITV goes under the throttle body unlike how the F is setup the IACV is still on the manifold.
        EDIT: Owned myself without reading the title.
          yeah...Im in the middle of cleaning my H23 head..( undergoing a H23/F22 hybrid )....and I was stumped as to WHAT goes under the TB
          and drinking doesn't help your memory either...LOL
          but yeah.....On top of the TB...do I have to JB weld a nipple for the Map sensor or what?
          MR Thread:
            Well if you still have the map sensor that goes on top then you can just put that in place and leave it. Thats how mine is on the h22
              Nope...no Map sensor ...didn't come with one!
              MR Thread:
                you might be able to use a little bit of jb weld
                  i have an IACV for a h22/h23 throttle body i could sell you and i would just make a plate to cover the map sensor area
                  -sean
                  Members ride 15.927 @ 86.76 (f22a1)
                  Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
                  Arcadia Green Crew #10
