Prob with my Car.
    Prob with my Car.
    Recently my engine harness melted and was needed to be rewired. Basically after that main relay was replaced 3 times to make sure it worked. Also the ECU was swapped to make sure the ECU is not damaged. When the car is cool, it will turn on any time. Once I turn it off when the car is warm, the car doesnt turn on. The only way that my car will turn on is if I let the engine cool off or disconnect the battery to reset the ecu. THen car starts back up normally.
    PS. The mechanic said its not the main relay or ECU. All fuses are working and he says, its better off getting a new shell or get a whole harness from the dash to the engine.
    1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
    *bump* any idea this is happening to my car?
