i was wondering if anyone knows how strict the emissions test is for maryland. also do you have any suggestions on what i should do to prepare such as oil change ect.
vehicle emissions
Well basic tune up, new sparks plug, wires, distributor and rotor, run some fuel injected cleaner. Make sure u catalytic converter and that O2 sensor is working. That should be enoughU silly rabbit don't u know tricks are made for kidz, You without me is like corn flakes without the milk! This my world, you just a squirrel trying to get a nut!!
fuel injector cleaner a week or so before, and the day before, fill up on the highest octane gas you can find and take it on a nice high speed highway run before you go for the testMEMBER'S RIDE
i was driving along today and the check engine light came on.
i pulled over and looked under the hood.
the engine was still there...
...silly light!
okay so i failed my emissions test. after the test i changed my spark plugs, oil, check the cap and rotor (both looked fine) and used some fuel injector cleaner. I couldnt find a new air filter but im gonna go check the dealer tomorrow. Is there anything else i should do? Should i change the fuel filter?
hc is distribitior cap and rotor
nox is egr ports....
maybe u just need a new cat...What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
