HELP......rpm
    HELP......rpm
    HElp
    ok i have a 91 cb9 with a 98' f23a1 auto
    and while drivin at 4000-5000 rpm the car is makin a weird nose plus it not chagin gears its only stayin at 2nd gear
    do you think its something with fuel.i did change the pump.
    HElp
    MY YOUTUBE Channel Plz Sub for the Support thanks
    ^^^ Click for the Link ^^^
    i would say the tranny is going out.. might do a tranny fluid change.
    and what kind of weird noise ?
    Originally posted by Devergote
    A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
      man dont say that.........but i change the fluid like two week ago.and top of that i went to orlando last weekend.
        does my tranny have a filter???????
          whats the weird noise like? need more info man. any cel? sounds to be electronic related Imo
            its coming from the engine.
            its the sound right before you change gear but it will last for a long time....like i said it dont want change gears.
              something please
                give us more info jesus
                  look at low rpm there is clickin under my car( right under the center of the the two front seats).
                  but when i hit around 4000 rpm the car does not want 2 change gears.
                  at the same time this started to happen my gas meter is not workin
                    i think you have a few problems first, maybe get a video? have you checked all the fuses and stuff?
                      yes all fuses are fine. like a week ago i change the main relay.
                        and the video let me try that out.
                          I had a simular problem. Does it work fine when just start it up and drive it and when it gets warn it starts acting up( making that noise and not changing gear like u said)? Thats what mine did so I just replaced it and did an auto to 5spd swap. Then thought to myself maybe it was the silanoids but i don't know what could have been wrong with it. Good Luck.
                            ever replaced a TCM?
                            just incase
                            http://www.cb7tuner.com/vbb/showthread.php?t=46042
                            cause i feel like i might get asked what it means.
                              no.....like this mornin when i went 2 school the noise got strong im thinkin its the driveshaft (i think thats the name)..... ......but once the car warmed up it did not make the noise.only once i got to a light.
