Does anyone know where i can find any of the OEM honda Male/Female Pins for the connectors in the under hood fuse box???Honda Dealership says they dont have them.
Electrical Pins
why don't you go to the junkyard and get them?Originally posted by JDM_honda_PIGDoes anyone know where i can find any of the OEM honda Male/Female Pins for the connectors in the under hood fuse box???Honda Dealership says they dont have them.
Why do you need them? I don't even know what your talking about so thats why i was asking why you need them
Maple50175 - you're annoying =P
^^As mentioned best bet is the junkyard. If not just pull a new fuse box from the junk car and put it on your car.
well if i go to the junk yard to get them the pins will already be used and i'm in the same situation as i'am right now. i'am wiring up my fog lights and using the factory connectors but, to do so without using butt connectors i need new pins so i can run new wire strait from plug to plug. i'm trying to do it the factory way...
My depo harness had an inline fuse and in line relay. Why wouldn't the junkyard work? I see fuse boxes all the time with the fuses still in themOriginally posted by JDM_honda_PIGwell if i go to the junk yard to get them the pins will already be used and i'm in the same situation as i'am right now. i'am wiring up my fog lights and using the factory connectors but, to do so without using butt connectors i need new pins so i can run new wire strait from plug to plug. i'm trying to do it the factory way...
I don't really get at what your trying to do. I know your trying to make your fogs look factory installed but the junkyard is cheap and it has stock parts
find out how many pins you need and then go to the junkyard. in the doors there are 2 pin and 3 pin harnesses, it may not be exactly what you need but you can make it work.
and since the pins arent the same as the factory harness that you DO have then just cut that plug off and wire in the new plug so that you can MAKE it work.
i do this all the time.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
what, are you looking for uncrimped stock pins?
i doubt youll ever be able to find them... ive actually swapped pins manually before though, if you use a stiff safety pin you can pry up the crimp, swap wires, and crimp it back down... but at that point, you might as well just solder or just butt connectors, and cover them with loom... itll look stock, and youll never noticed the difference afterward...
honda has them, but they will not sell it. plus, us tech will not even use new connector, we'll just take those pins out from another harness and wire them to whatever we need to. as stated above, junkyard,Originally posted by JDM_honda_PIGDoes anyone know where i can find any of the OEM honda Male/Female Pins for the connectors in the under hood fuse box???Honda Dealership says they dont have them.
[QUOTE='cp[mike]']what, are you looking for uncrimped stock pins?
YES, yes i'am, the female pins actually the relays i'm wiring into already have the male pins, i just need the female side to wire up to the empty slot in the connector, actually i need like 10 female pins.
dude, i cannot use crimped pins, and i'am not trying to swap out the plug/connector mine is fine, i just need to add a wire into it and for that i need pins, i wont be able to find this part at the junk yard.Originally posted by jhondayaajhonda has them, but they will not sell it. plus, us tech will not even use new connector, we'll just take those pins out from another harness and wire them to whatever we need to. as stated above, junkyard,Last edited by JDM_honda_PIG; 10-13-2007, 03:51 AM.
i have an extra fuse box =).
http://www.installer.com/hardware/
there is a few things there like fuse taps...i think i know what ur trtying to do now.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
oh your just trying to tap power for the fogs...i see.
honestly all you need is a constant from the battery, and an acessory lead from the ignition column. and probably a relay...technically its the same way as factory.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
