OK so here's the deal. I got an intermittent CEL 22 (vtec pressure valve). I've traced it down to jiggling the pin for the vtec pressure valve in the wiring harness that plugs into the ECU. Sometimes it works, and sometimes it doesn't. I've tried multiple ECUs, so I'm pretty sure its the harness side of the connector, and not the ECU itself.
The pin jiggles a little bit in the connector, but no more than any of the other pins.
I'm wondering how I can/should secure this pin better so I don't have this problem. Any suggestions?
thanks
thanks
