which TPS will fit??
    i need a new one for my h22. will an accord tps work also?
    yup, the F22 TB used twist-off headed bolts so theres no head to take it off with, so you need to slot the two screws with a dremel so you can use a normal flathead screwdriver to take them out. or you could just grind the heads completely off. reuse the H22 torx screws to hold it onto the new TB, because those are easily removable. im currently using my F22 TPS on my h22 because mine came broken.
      You can use any honda tps, that isnt obd2. If you take yours off, and go to the honda motorcycle dealer, you can buy a CBR tps i think 96 or 97 not sure... a lil modification is required, but its only around 35 dollars brand new
        is h23 tps interchangable with the f22?
        Retro!
        Hater
          ANY TPS WILL WORK B SERIES D SERIES, as long as it is not obd2
