i have just recently worked on my brakes doing everything that is possible to make them work properly. i just replaced my M.C. and bench bleed it, bled all the brakes starting from the farthest tire away from the M.C. i got new pads, just recently replaced the calipers, and had the rotors and drums resurfaced. but still i have to push my brake pedal almost to the ground to get any resistance. ( this is with the car on, when off the pedal stiffens normally) so whats the deal, ive never heard of the power brake booster going out on hondas, and the only left that i have not touched is the proportioning valve or the power brake booster.
