resistor box wiring
    resistor box wiring
    Sup guys I'm so confused and I'd like to understand how some of this thing works since I'm taking electrical class now.
    1. What's the purpose of the resistor box.. Resistor is like resistance.. So they added resistance to the circuit so the injector doesn't spray a lot or what?
    2. Okay I'm lost I need someone to really help me on this one okay my friend has a turbo car with rc 550cc injectors...
    Okay now what he did was cut the yellow wires off the dead plug located by the brake master cylinder..... he took his meter did a continuity test and figured out which wire to connect..this is where I'm lost...
    Still 2. When u take the connector.. How do u know which 4 of the yellow wires are the power wire. Do u just leave the car in the acc pos and see if meter reads 12v ?
    3. Now that u find all 4 of the pos wire that are injector wire you cut it or splice? And what's next after that my friend did continuity tester not 2 sure what's the steps on that.. But I believe the wire he cut he put one of the meter leads on the cut wire and the other on the resistor wire until one of the wire beeps. Than he connects it..
    4. What's going on here I'm lost and diagrams or videos very lost..
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
    Wow that gave me a headache
    PETRA tow montebello
      What was he cutting the wire for anyway, if its a dead connector he should just backprobe it...you're friend aint very bright. But I still don't get the point, are you having a problem with it running incorrectly?
      Proud owner of the only JJDM full 2.5" catback exhaust!
