f23 vs h22 clutch disc
    is the f23 clutch disc the same size as an h22? i know the h23 and h22 use the same clutch assembly. also the f22 clutches are smaller. ive also heard that the f22 came with clutches that are smaller and the same size as the h22.....help.
    either way...it is all interchangeable.
      i know that. but is the f23 smaller or same size as the h22?
        if it is interchangeable, it should all be the same size however, different manufacturers will make different sizes.
          thats the thing. ive got a 4 puck, unsprung race disc from Tampa Clutch Supply.
            with what flyhweel? if it fits on kthe flywheel, then you are all set.
              h22 flywheel. ill just buy an h22 one. i cant afford for it too not fit right now. my situation is complicated, lol.
                so are the h22, h23, and f22 clutches different sizes? Will they fit on and f22 tranny? if they are bigger than f22 will they stick out of the pressure plate or will it work?
                ____
                  h22 and h23 clutch assemblies are exactly the same. f22 clutch assemblies will work on both f and h series trannies. im temporarly using an h22 clutch assembly with my old accord tranny.
                  i measured the f23 disc too my old f22 disc and its the same diameter. BUT ive heard the f22 clutches came bigger and smaller......wtf?
