Ok, I heard its impossible to set timing on a 5th gen prelude. Because of the fact that its OBD2, that sounds like it could be right. I checked it today, and it was around 15 degrees at idle when warm. Does anyone a)know if i can set it, or b)know what the degrees should be set at.
This whole problem came around because I'm getting a vibration at idle. I hate when my door panels rattle, and my headliner, and other various trim rattles even a little bit and I want to fix it.
I just put new plugs, cap and rotor on it a few weeks ago. I put NGK Plugs this time, but last time I had Bosch Platinum +2's and they were BLACK in like 5 months. I probably put 13-14k miles on those plugs but that still seems a little fast for them to be fouling out, right?
I need some more ideas for what this idle issue could be, whether it be mounts, a fuel filter (which I have already, but its a bitch to change), or anything else you guys can think of.
Thanks as usual guys.
