OK guys i have been looking on here alot about doing a turbo setup on the f22b dohc and want i want to know is how much would i push in horse power with a t3 t4 turbo and and good tune with a chipped p06 i know how to do all the work just want to make sure that i am not going to mess anything up if i run at 10 psi for a daily driver.
f22b dohc turbo
put the kit together, install it, and get it dyno-tuned THEN you'll be provided with hp/tq and a/f numbers...
starting a thread asking for how much power you'll b putting out is non-sense
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
t3/t4 is very specific....
Ok NAIL05 what do u mean by t3/t4 is very specific and guys i cant find a fmu in 4:1 ratio. Ok guys give me a list if u don mind what u kind i should do to the motor before i turbo it. I have about 2000 for it all. So help a guy if u dont mind i have been searching on here alot. I cant find much on if any one runs that much on a daily driver what they use and if it holds with the motor. And if u could recommend a ok t3/t4 turbo for not to much.
Originally posted by 10thcb7Size matters....
16G FTMFW
NOTE: in order to use the 16G or 20G for that matter..you would need a DSM turbo mani
here you go mayne!
get this manifold ( redrill to fit ):
http://dsmparts.com/customer/product...620&cat=&page=
get this turbo ( 20G ):
http://dsmparts.com/customer/product...cat=166&page=1
or ( 16G ):
and then...just for you own intercooler and charge pipe setup! ( have a shop fab up charge pipes for you...OR if you're good at welding/cutting..you can make your own charge pipes and DP from turbo!)Last edited by SN2BH22CB7; 01-10-2008, 08:46 PM.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
Did you really just recommend an FMU?Originally posted by 10thcb7No at 10 psi a t3/t4 turbo is large enough to lag and not cause alot of heat because it is not spinning at full potential. If a D15/B18 block can handle 10psi at max a F22A/B can handle it too. Just make sure you atleast get some sort of engine management. It is NOT reccomended but you might want to use a FMU with a 4:1 ratio.
I should slap you.
Originally posted by d112crzyDid you really just recommend an FMU?
I should slap you.
as sad as it is to say... that looks like the route he's gonna HAVE to take since he said there's noone in his area that tunes
sucks balls
My Ride thread
Flickr
whoah man... i'm SURE he ain't mean it that serious, he's just a BIG chipped-ecu supporter, that's allOriginally posted by 10thcb7^seriously crzy; read the post before I reach back like a pimp and bitch slap the taste out your mouth. I recomended some sort of engine management. I clearly state that the FMU is NOT reccomened but I leave that as a viable option. Whatever man Im not trying to ethug or cause noobs bad info. FMU's are still used by people that cant get tunes. i.e.
it's all good man, just take it ez
My Ride thread
Flickr
Fuel Management UnitOriginally posted by NorcoAccord:
But whats an FMU?
http://www.inlinefour.com/bloxfuelmanu.html
My Ride thread
Flickr
if you can't tune...you will not achieve full potential...even with a smaller turbo.
You NEED to tune a turbo setup...dare I say have to...but I dare not...dyno is the best way...worth finding one...crossing state lines is allowed
though not all that practical...but neither is a turbo setup...so you have to do things to run it right.
__
__
