Manual transmission fluid
    I'm about to order up some fluid here. Going to go into my friend's 1991 Accord LX 5 speed, and also into my 2004 Civic LX 5 speed.
    I'm looking at this manual transmission fluid... should be enough to change both our transmissions with a quart maybe two left over.
    Let me know what you guys think. I'm just about due on a change on mine and my buddy is a bit overdue.
    http://www.inlinefour.com/honmantranfl.html
    Thanks!
    I tried search and didn't find much that would help my question.
    Just go to your local dealership.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Or would I be better off goin to the dealer? I'm drivin out to my brother's house tomorrow which is right by a honda dealer I may stop there and see what they have too.
        haha thanks. I just feel better putting the OEM stuff in there.
        I read all over and there are huge debates on what fluid to run. The only constant I saw was no one really had an issue running the factory stuff.
          I think the manual tranny is not as sensitive as the A/T when it comes on fluids.
            my friend just told me get some 10w-40 and half quart lucas stabilizer.
            Anyone actually know the difference?
            Vouch for: Jarhead293, 2.2litrebeater, Darkshadow707, slammed4thgen, Pacman91ex.
              I just use regular 10-30. If you want something thicker, you can use 20-50. Regular engine oil is all you really need.
              1992 Prelude S w/swapped H22A
                doesn't acura have some new MTF similar to GM synchromesh?
                  using engine oil compared to actual MTF is a HUGE difference.
                  trust me. I used 10-30 for over a year and then used honda mtf.
                    just use 10w 30
                    I-SR 6
                      I <3 syncromesh.
                      To-Do List for Today
                      Be Awesome
                        just filled mine with all synchromesh. heard it does wonders on trannies.
                        Originally posted by d112crzy
                        So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
                          Torco MTF is an option.
