Adjusting Window
    Adjusting Window
    Hello All,
    I need to know how can I adjust my driver side window. Its works fine being that it goes up and down, but when it almost hits the top (fully close) it seems to move a little forward and then I have to manually oull the glass window back with my hands. How can I adjust it so it lines up right with the door?
    thanks
    slam-
    I can accept failure. Everyone fails at something at some point, but I can't accept not trying". MJ23
    Time and Money BOTH is why I do what I do
    i had the same problem,i fixed it by taking off my door panel and there is 2 bolts that hold the window on its clips take out the bolts while a buddy holds the window (careful) if it just needs adjustment than just loosen them enough to slide the window were it needs to be.than tighten the 2 bolts but not to tight !
      Yeah, I actually just did that today. Tho, I then compared my left and right windows and the right one moved a lot more then the left if you just grab it try to rock it forth and back. The solution in this case is a new regulator but I decided my adjustment did the trick for now so I'm gonna hold off on a new regulator.
        Welp, go to roll up my window this morning and the damned thing tips forward again Don't know if I want to bother with a new regulator just yet. We'll see if I get really annoyed with the whistling first.
