Rod knock
    Rod knock
    It happens at all rpm right?
    Does this sound like a rod knock? right before this i changed the oil, its at the right level and everything.
    wat?
    wat?
      Rod knock is normally loud, I cant hear it well but it sounds like a faint ticking on the video. Could be valves but I cant hear everything clearly.
        Its when I let off the gas and it drops down to 2000-1500 RPM its like a clunking noise kind of. I can hear it in video its just a little quiet
        wat?
          i dont hear anything unsual other than the normal valve tick of a f22?
          I <3 G60.
            Alright cool, just wanted to make sure!
            wat?
              try getting your valves adjusted first, then go from there.
                I did before winter.
                wat?
