h22 head on f22 block
    IS it true that you can attach an H22 head onto a f22 bottom end? all i need in the head and intake manifold and all the wireing to wire the vtec and shit. I think it would work cause the engines are identical.
    Yes you can make it work, BUT, the stock F22 bottom end is only built to handle the stock f22 rev limit. where as the H22 bottom end is bettter built to handle 7200rpm.
    You'll also have the low compression ratio to worry about.
    So basicly if you want to get some DOHC VTEC power under the hood, it's better (and cheaper if you want it done right) to just get the whole engine to begin with. It will be much mor relibable that way.
      I would feel better getting the whole engine cause mine has a lot of miles and it is an automatic.
        Yeah man I'd def go that route. You could even do a manual trasmission swap if you got a newer H22 engine and trasmission.
        We have a DIY posted in the DIY section for that swap.
