its a pretty simple thing really. For those of you who dont have your cruise control anymore but still have it and have the button sitting thier it can easily be converted to a tailight killswitch where it wont light up your brakes when cruise control is off.
You need a non CC brake switch from any auto parts store should cost anywhere from 13 to 23 dollars.
take out the old brake pedal switch with a 14mm wrench now you need to cut the old wire harness of the wires coming from the car.
thier will be 4 wires coming to that harness. splice the 2 big wires and cut the 2 little wires.
then put to sliding crimps on the ends of the two big wires and slide those crimps onto the new brake pedal switch.
install the switch and wallah when cruise control is off your tailights will not work, its good for getting away from cops when you need to brake but dont want your tailights turning on and its basically oem.
maybe its really stupid but i think its cool and a good use of the switch taht is just sitting thier.
Hey, Grandma! You want a lumpkin?
with 260k on her
I've e-braked in the past.
so might as well make good use of the button
