where is the iacv located and what mark on the tac is 600 i believe it to be the 3rd but just want to make sure i know this sounds like a dumb question but i dont know alot about these engines
ENG: Setting Base Idle Properly (F22ax, F22bx)
Originally posted by 91dxaccordcb7 View Postwhere is the iacv located and what mark on the tac is 600 i believe it to be the 3rd but just want to make sure i know this sounds like a dumb question but i dont know alot about these engines
600 RPM is first small line above the thick one on RPM gauge (tachometer). The thick line represents 500 RPM.
Just adjusted my valves, much more power and easier pickup. Cleaned the EGR ports and valve. Now my base timing is a bit low.
The idle adjust screw, is it adjust with a flat head or philip? I have a 1990 Accord LX 4AT.
It seems like a flat head and mine is all the way out but to increase the idle I turn it CCW, would that unscrew it all the way out and come off?
How deep is the idle screw in the hold by the throttle body? I am thinking that is a plug in front of the hole and not the screw itself.
My base idle is at around 650 instead of 750rpm. When unplugging the EACV it drops to about 100 or 150 but the engine does not turn off. CEL lights up.
The screw looks like it has some kind of paste or glue on it.
Please advice further on what I can do.
Thanks.Last edited by Bad_dude; 08-13-2010, 02:48 PM.
Originally posted by 809king View Postcan someone help me. i went through 4 iacv's trying to adjust the idle but every time i used a flat blade screw driver it rounded the screw and i tried different size screw drivers.
i have two more and dont want to keep stripping them can some help
IT IS WHAT IT IS
The IACV (idle air control valve) is an electrical solenoid that allows more air into the engine to raise idle under engine load conditions. The IACV is fastened to the intake manifold plenum by 2 flange-head hex screws.
I understand your problem with the idle screw slot for flat-blade screwdriver. You need to remove the silicone, if there is any. Then, you need to use the tip corner of a flat-blade screwdriver to make the slot deeper. Do this until you have a deep enough slot. Then, use a flat-blade screw driver that is about as side as the slot, apply pressure towards the screw while turning. Once you break it free, should be easier from there.
Are either one of these the IACV? I don't remember what they are called.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
Originally posted by CB7uner View PostThis is an awesome DIY...but where is the screw exactly located that you are supposed to turn? I'm new to these engines.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
