tools needed
-heat gun
-leather glove or rag
-phillips screw driver
-carbon fiber wrap
-19mm socket
-ratchet and extension
-2nd set of hands but not needed
-flat head screw driver
"BEFORE YOU BEGIN MAKE SURE YOUR WHEELS ARE STRAIGHT"
for the people that dont have anyone to help, this is what i did to hold my heat gun
start by removing the "H" and the nut inside
wiggle the steering wheel out far enough so u can disconnect it
now that you have it out unscrew the 4 screws on the back
push out the connecter
unscrew 4 more screws and disconnect the connector circled green
remove the 4 springs and place them somewhere safe
you dont have to sand it,i did to make sure it has a smooth flat surface.or you will get small dents after you finish
sand the back so that the wrap sticks on better
cut out a peice not to small
pull the the back off an place the object in the center "didnt know what to call it lol"
now this is where it gets tricky.if you never worked with vinly wrap before it will shrink but you can strech it when it gets hot.dont over strech it or you will ruin the design.dont worry if you get wrinkles,you can get rid of them with heat and smoothing them out.this is where a glove comes in hand or just place a clean rag over your hand and rub firmly and set the material while applying heat to mold it
cut an "X" in the middle not all the way
apply heat and modl it
cut the remaing sides so that it will stick on better and again heat and mold it
apply heat and put the "H" in so that it will mold it better.leave it on
now while applying heat fold the exesse wrap and mold it to the back.I cut the wrap so it will fold better.
now go along the back and cut along the side so that the wrap will stick better when you press down on it.you dont have to apply heat
now put everything back together.dont forget the 4 springs you removed.and enjoy your cool looking steering wheel
some other parts i did
my brothers
-heat gun
-carbon fiber wrap
-19mm socket
my brothers
