ok, everyone knows that the DC2/4 integra clock fits perfect and so a lot of people swap it, just pop out the old clock from the left side with a hack saw blade (thin and could move around the clips on the clock)... unplug it, (4 wire plug), then plug in the integra clock and ur set, well pop it back in, anyways, here is my twist on it...
i did this mod last night and it is siick having a white clock for change right, well this kinda killed it, cause when i switched on my headlights it got really dim and kinda didn`t impress me cause it was a dull white, so i popped it out and took a wild guess and cut or severed the red wire for the clock wiring harness, and it was the dimmer light wire, so now at night it is hella bright and wether the lights are on or not then the clock doesn`t change brightness, hell, even do it if u have a stock clock, it glows and is a cool DIY, later-
