The F-Bomb
Engine:
F22a6
86 mm Arias 10.5:1 pistons
Eagle "ESP" H-beam rods.
Toga high volume oil pump
ACL bearings
Supertech dual springs and retainers
Web Cam regrind #1160/273
3 angle valve grind (stock valves)
Innovative mounts (90a)
Intake/Exhaust/Fuel:
F22a6 lower plenum/H23a4 upper plenum
H23a4 throttle body
AEM V2 short ram
DC Sports ceramic coated header with 2.25 in. collector
2.25 in. 304 stainless mandrel bent manifold back pipe
resonator and muffler not chosen yet
RDX injectors
AEM fuel rail
AEM fuel pressure regulator
AEM fuel pump
Trans:
T2T4
Syncrotech carbon syncros (not purchased yet)
f23 shaved 5th gear (not purchased yet)
Cheddas shifter cable bushings
Cheddas shifter plate solid bushings
Cheddas single bend short shifter
Suspension:
BC Racing DS Series coilovers
12k front springs/7k rear springs
Prothane master bushing kit (black)
FFC rear lower control arms
FFC rear toe arms
Innovative traction bar
ST sway bars
X2 Industries front upper adjustable control arms (to be acquired)
manual rack conversion (swapping to electric pump steering soon)
Engine Management:
P06 with Hondata
AEM wideband
Autometer Z series oil pressure gauge
Body:
red/clear taillights
clear turn signal lens
Honda moon roof visor
Interior:
black dash swap
Corbeua FX 1 Pro seats and tracks (to be acquired)
harness bar and 2 inch web cam lock harnesses (tbd and acquired)
black carpet from Stock Interiors (to be acquired)
bb6 center console
all interior painted black with Duplicolor Vinyl and plastic paint (to do)
#7 pool ball drilled and tapped for shift knob ( will change, suggestions welcome)
This car is going to a bare chassis for this build, grab some popcorn and enjoy. I may be forgetting something and the parts list will continue to be updated as I acquire more.
