Idle Problems? Look Here.
    alot of people keep asking "whats wrong with my idle it jumps up and down like a wetard" well heres a good detail video by EricTheCarGuy on youtube.
    http://www.youtube.com/watch?v=L788j..._order&list=UL
    hopefully this helps
    Common beginner technical info. Go read it.
    MRT
    sneaky motherfucker
      idle problems reply
      why would you want to watch a 9min video when you can read fast answers here...i had the same problem,i simply removed my throttle body and cleaned it out with throttle body cleaner.i also cleaned out my iacv and fast idle valve.you can see them bolt on the upper plenum of the intake manifold.but if you want to go all out,then buy yourself some new intake manifold gasket set and just overhaul the thing.best way to chek for cracks or leaks.
        well sorry i thought id help out but i guess forget since people want to just be a dick
          Dont worry man, its a useful vid. Its good because it provides visuals. Thanks for posting and Ericthecarguy is the bomb.
            thank you. i just wanted to show something with details and images of what to do. most people would be lost with just words
              thanks for the post man. i like being able to see it rather than just read it.
                idle reply
                its best to read a couple of paragraphs,get the idea of where the problem is and do the job..if you dont get it rite, read some more till its rite,the only way to learn from your mistakes.that is how all master techs started.from a noob to a master
                this is how i do learn about my car and motors..from turning screws to swaping motors n trannies,overhauling,modifying.im interested in tuning ecu's and i know its a bitch,but hell im up for the challenge..
                  well true but it can also help the people that are not familar with cb7's or hondas in general.
                    idle reply
                    alrite bro,you the man..im not putting pressure on you,i just want to put in some info..please dont take me as a negative.but we do love one thing for sure,our cb7! peace.
                      nah you good
                        That vid does a good job of summing up the checklist for idle issues. Great vid.
                          Some people learn stuff by watching it and some by reading it and visualizing it in their heads. Useful vid though
                          MY MRT
                          http://www.cb7tuner.com/vbb/showthread.php?t=178936
