**im not responsible for damages**
seals never last forever. once the fuel rail starts leaking you just have to replace the seals. the seals total will cost around 60 bucks from the dealer. you might as replace all 3 on the injector.
tools you need:
13mm ratchet, wrench
17mm socket for fuel line.
10mm wrench/sockets
rubber gloves
flat head, small
Time: 1 hour.
procedure:
1. Open the fuel cap and release pressure
2. park on the street so that fuel that leaks goes down to the street.
3.
remove the 3 10mm bolts, and the big 17mm bolt that i marked in red
then remove the 2 10mm black screws from that plastic rail circled in purple.
on the injector there is this gray clip on it, you need to remove the needle type clips from it to the side and then lift it up so that plastic thing can be moved out of the way. use a flat head for it. dont worry you wont break it.
4.
take the 2 10mm bolts off of the fuel pressure regulator (FPR)
5.
move that plastic thing out of the way, all the gray connectors should be removed.
6. now you may be able to pull out the fuel rail, but what i do is nudge each injector out of its hole inside the engine and then pull it out with the fuel rail all together.
*when you take it out, dont clank it against any thing. you can damage an injector.*
7. pull the injector from the fuel rail 1 at a time.
there are 3 seals on the injector, the one that seals the fuel is the first small top one. those are the ones that go out faster. take the old one out wiht a screw driver and then put in the new one with a small amount of vasteline A SMALL amount. this will be enough to lubricate it.
now you may notice on the yellowy end of the injector that went inside the intake manifold there is some black crap on it. get a paper towel and wipe that off. thats carbon from years and years of build up.
****there are little plastic kinda washers that may come out when you take out the injector or it may still lie inside the hole for the injectors, take those out and clean them and clean in that hole with a toilet paper. ***** dont buy new ones, they just sit the injector in place.
so replace the seals for every one, might as well since you got it out.
8. OPTIONAL
get some fuel injector cleaner like lucas and put it in the top of every injector, just a drop...and put a little in the fuel rail and put a little inside the intake manifold. this will SUPER CLEAN the system kinda. be warned it will smoke on start up.
9. installation is reverse of the removal.
-have all the injectors in the rail and slowly put it back. fit it niceley so that they seal up. and the bolts are ready to be bolted in....snugg it and bolt it down. dont over tighten it....just nudgely do it in this format 1-3-2 bolt pattern since there are 3 bolts.
-put the plastic rail back on with all of the clips. now fix the clips so that they are on like when you removed it. then it should just clip on you will hear a click when u do it.....and dont forget the 2 black 10mm screws on it, NOT TOO TIGHT.
-put back the FPR tightly!
-connect the fuel line with the washer on the bottom, the line, then a washer on top then the 17mm bolt, tightly.
check that everything is on there. nice and snug.
now put back the fuel cap. and then turn the car into the ACC position. go back in the engines and check for leaks around the fuel inejctors. let that sit for a minute.
then start it. this will take a while to start, about 10 seconds. thats cause there is air in the fuel system, and if you put fuel injector cleaner in there it will take longer to make a nice mixture.
when it starts check the engine for leaks again especially the FPR. then revv it a couple of times, especially if you put fuel injector cleaner, you will see white shit comming out of your muffler. mine took about 10 minutes to clean out.
clean up, constantly check for leaks. take it for a ride.
enjoy. over the next couple of days look for leaks....you may want to wash down your engine with all that fuel you leaked.
congrats, you have done it.
if you have any questions contact me through PM or AIm sn: pino401 and email peepoy@hotmail.com
tools you need:
10mm wrench/sockets
rubber gloves
flat head, small
Time: 1 hour.
procedure:
3.
4.
5.
8. OPTIONAL
