Got it replaced at the beginning of january and has been acting funny, its a honda accord 92 lx atoumatic and it runs somewhat normally on flat or downhill roads (somewhat meaning that I only hear it change gears from first to second but thats it) but going uphill I notice it gradually raises in rpm from 2 1/2 to 4 rpm, would not go any faster, and would never go down unless I make a complete stop, when I park my car I noticed smoke coming from my hood and underneath the car, wasnt thick but was white and can be seen if you look carefully, is it the transmission that can be the problem, and if not, what could be. Thankyou so much for taking the time to read this and I appreciate some insightful feedback
Replaced transmission but still acting weird
if you still have a warranty on it take it back asap.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
