(I was not sure where to post this, please move it if needed).
I've been searching for over an hour without much luck. I found one post by cpmike about de-rusting a manifold but his youtube links did not work (original owner removed account) and he also stated later that the process failed (paint bubbled off). I could not find any other posts on cb7tuner regarding this topic. I found other mustang forums that mention taking a sand-blaster to manifolds and having it professionally cleaned (sand-blasted, primed, baked, painted, baked, x2).
I was wondering if anyone has any ideas on how to clean the below unit? It's cast iron, very heavy, very thick and its just surface rust. I read about using sand paper, or a bristle brush, and other methods and I wanted some opinions. Obviously the area that meets the head will need to be sanded and painted to have a proper seal too. Does anyone have any ideas that I can personally do here @ home? Has anyone been in the same situation?
Would a wire brush make this look bad? (the brush cannot reach all areas).
Would anyone recommend just sanding off the few rust spots and painting the whole thing? (scuff the non-rusted areas)
Or should I take this to a body shop and have it done by a pro?
(I can take more pics if needed)
