how hard can this really be? my 90 accord didnt come with ac has anyone ever added ac to a car that didnt come with it. i know peeps delete the ac all the time, but im talking about adding it.
adding AC to a car that came w/o
Ride List
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6Tags: None
Originally posted by cloudasc View PostYou would need an entire hvac system from a cb that came with a/c. This means your having to tear your dash completely apart to do everything, not just the majority of parts that are found under the hood. It would probably be easier and cheaper just to buy a cb that already has a/c.
Ride List
Originally posted by blazenem View Postyeah that's what i figured, was gonna get another CB that has it installed as my DD...just thought maybe it was lines, harness, compressor, condenser, and the thing under the dash what is that called?
(Evap = Evaporation)MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by GeoffM View PostEvap coil. In order to add it, you need to remove your dash.
Ride List
Evaporator coil R/R can be done by removing just glove box and related parts, not entire dash. My computer geek son did it by looking at Haynes manual, not needing my help, except on installation. He needed someone to guide and pull drain hose so it will not be pinched upon installation of the coil assembly.
But, still, it would be cost effective to find the car with A/C installed already compared to retrofitting it from other cars if you ask me.Last edited by oyajicool; 05-02-2012, 04:41 PM.A&P-IA
Its not hard to do at all. The a/c system is designed to be installed in a car at the dealer as an accessory.
Your car is already pre wired for a/c so thats a major step thats already dealt with
The evaporator coil can be easily accessed by just removing the glove box.
basically you need to add the compressor, compressor bracket, condenser in the front bumper, hard lines and an evaporator coil. Oh and don't forget the switch.
Its not hard, i've fully removed and reinstalled mine on my brothers car before. it takes about 2-3 hours to fully install it.
Don't listen to people in here. It would neither be cheaper or easier to get a cb7 with a/c. Chances are finding one that still works will be hard itself. The system and its componets i'm sure could be had at a local junkyard between $100-$200. For the 2-3 hours of the install i think it would be well worth it.Last edited by Tippey764; 05-02-2012, 05:50 PM.
I have had to replace my blower fan motor, (and yes the glove box was removed) and that was an utter pain in the ass in my lx coupe with a/c, sure you probably could squeeze everything in without tearing apart the dash, but you'll probably spend more time irritated and pissed off then if you would have torn the dash apart. Oh and the haynes manual sucks !#$%&* in regards to instructions to replace the fan motor for my car. So if you are going to undertake such a feat (like adding a/c to a non-a/c car), make sure you have a helms manual handy. Just my two cents.
Also doesn't the dx have a different vent operating system, that is missing the evaporator?
Removing and re-adding the a/c system on a car that came with it is different then a car not-equiped getting it added if I am not mistaken.Last edited by cloudasc; 05-02-2012, 08:42 PM.
Its not
It has a duct that replaces the evaporator coil
You simply remove the glove box and its mounting bracket. Then you remove the 4 bolts on the bypass duct and remove it. Install the evaporator coil in its spot
The evaporator coil is very easy to remove. The hardest part is disconnecting the high/low pressure lines if you have a car with ABS.
also if your going to attempt this make sure you add your receiver dryer and while your at it a filter... and check oem specs the RD and Compressor should be hold a certain amount of oil before the system is charged... also make sure you lube only the out side of your seals with A/c mineral oil... and you'll probably want to use R134a since it would be expensive and hard to find R12 which means i would use POE oil in the system... oem calls for mineral oil but that should only be used with R12, PAG is for R134a but since you're retrofitting the system i would use POE as it is suitable for both. PM me if you need any help or have any questions... just got my 609 certification... lol
Also I thought the dx had a different "thermostat" that uses manual cables to open and close / change the vents, vs a motor, does that have any effect on the system? Or do dx's also come fitted with the motorized vent selection / thermostat?
Ride List
The only part thats powered on an LX/EX/SE is the vent position, that motor is on the left side of the heat ex changer
Regardless you aren't touching that part, you're removing the part next to it. Its all compatible. Just make sure you grab your a/c from a non abs car. Well it doesn't matter if you grab the whole system but FYI the connection through the firewall has different fittings on an ABS car to clear the accumulator.
