oh man... the fitment sounds so gross o_o how did that owner make it look so flawless on their car??? I guess the search for a rear lip continues >_<'
Ultimate REAR Lip FAQ
Originally posted by P5ylance View Postoh man... the fitment sounds so gross o_o how did that owner make it look so flawless on their car??? I guess the search for a rear lip continues >_<'
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
I just want to touch on the original post in this thread about the CD5 lip.
The CD5 lip only works from 94-95 models. The 96-97 models have a more curved style lip which does not fit the CB7. I got one from the wreckers and tried to fit it, but could not make any of the angles work. The 94-95 style, as posted in the original photo is the only one that will work, since it's a little more squared and matches the CB's bumper and is easier to cut and bend to fit.
Also saying it needs extensive modification is not true. It needs a triangular notch cut into the bottom corner where it will bend. Also, if you do not have mudflaps, you'll have a gap, similar to a Legend front lip.
This is probably one of the easiest DIY lips to modify and install.
Look closely on the passenger side, you can just see the small notch cut in the bottom. That's all you need to do. You also need to chop about an inch or so off the passenger side lip for the exhaust opening. For the centre piece, obviously just cut it to length.
Originally posted by TuneAccordingly View PostDoes this work for you? http://www.absdynamics.com/90-93-hon...9093MU_204.php
..edit.. importparts.com sells that exact same brand lip for .108 instead of 120 which pretty much takes down to original seller minus sipping. Think I will grab one in a few days.Last edited by Smokinspeeds; 06-02-2012, 11:13 PM.
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
