Hi there guys. I just recently slammed my accord and I'm having a lot of problems. I have some ideas on how to overcome them, but I would like some opinions.
My first problem is my cv axels. Because of the ride height and somewhat of the natural camber I'm getting a slight vibration. When I look at them they are at very unnatural angles.
One of my ideas to potentially fix this is shimming the motor mounts to lift everything up a bit more. Not only would this straighten out the cv axels.. (to an extent) but it would also give me a little more clearance from the ground. As of right now my exhaust scrapes everything that's not completely smooth. If anyone has ever attempted to do such I would be grateful if you shared your experiences with me. Another problem I am having is my upper control arms bottoming out on my inner wheel well. I have somewhat fixed this problem by cutting a hole under the hood but I think I need to go bigger. I have seen other people do it, even my buddy cut his out on his eg. Please post pics if you too have done this. Another problem I'm having is the tire seems like it's hitting the inside of my wheel well at the same time. It definitely rub s when I'm taking a sharp turn. I was thinking about some wheel spacers to bring it out a little more. Right now I have an inch and a half of clearance from the outside top of my tire to the inside of my fender. (As you can probably tell from that I don't have offset wheels)25 mm spacers converts to just under an inch so I would still have a half an inch of clearance. Thanks ahead of time guys.
