Old 06-25-2013, 11:59 AM   #1
wildBill83
wildBill83 seems to have made some friends!
wildBill83 : 1992 Accord LX
So this is the car I just bought the other day for $550. It's a maroon 4dr LX 5spd.
The good, it has no rust and a decent body and it is a manual.
The bad, it was owned by a moron, who ruined the cooling fans because he thought they were both supposed to run all the time, now the primary fan only runs when A/C is on. This caused the motor to over heat and the water pump to fail. He also decided JB Weld belongs in CV joints.
Needless to say I'm just tearing into the car to find out what else he "fixed".
REPAIR LIST (Completed)
Clutch and throw out bearing
Air intake tube
Upper front ball joints
Lower ball joints
Outer tie rods
Sway bar end links
Upper rear ball joints
Drivers axle
Passengers axle (acquired from 92turboaccord)
Fan wire harness repair
Radiator Cap
Water pump
Thermostat
Dizzy o-ring
Cam o-ring (acquired from dj_ender)
Water neck inlet seal
Head gasket
Valve cover seals
Rear main seal
Oil pump crank seal
Torque motor mount (Poly filled old mount)
Side motor mount (Poly filled old mount)
Rear motor mount (Poly filled old mount)
Transmission mount (Poly filled old mount)
Small interior pieces
-Shift boot
-ash tray
-cup holder
Missing exterior items
-Emblems
-Mud flaps
Exterior wire harness shorts
-A/C fan
-Cooling fan
-Drivers side headlight
-front lip from an EX
Missing under hood brackets and items
REPAIR LIST (Needs)
Rack & Pinion rebuild
Lower frame front cross member is damaged, may replace...
Front right fender dent removal
Rear right passenger window regulator
-Battery tie down
Interior wire harness shorts
-rear pass side window
-dome light
-passenger door open switch
-Antenna
OTHER UNKNOWNS
MOD LIST
CB9 trunk compartment
ENGINE
STOCK F22A1
H22A4 windage tray
H22A4 oil cooler
TRANSMISSION
STOCK H2A5
EXTERIOR
STOCK
INTERIOR
STOCK
SUSPENSION/WHEELS
STOCK
(Refinished SE rims eventually)
AUDIO/ELECTRONICS
Pioneer Head Unit
CB7 EX 6x9 Rear pods
FUTURE PLANS
Possible suspension upgrade
Rear disk brakes with 40/40 valve and sub frame and sway bar from an SE if I can get one in the junk yard
Repair and replace missing items from a junk yard.
DD stocker until I get another good paying job
F22A6 cam
F22A6 or H23A intake double runner + functional IABs
F22A4/6 exhaust manifold and dp
Convert PT3 to PT6 using cloudasc kit
Possible brake and clutch line upgrade to SS braided
Drive her for a while then drop the H22A4 in her.
wildBill83 is offline   Reply With Quote
Old 06-25-2013, 12:40 PM   #2
AAPOQ
Procrastinator
AAPOQ seems to have made some friends! AAPOQ seems to have made some friends!
Nice score, man. Hopefully you don't find too many other issues.
AAPOQ is offline   Reply With Quote
Old 06-25-2013, 12:48 PM   #3
93Accordian
93Accordian is cool... so far.
Looks good!!! JB Weld in the CV joints? Lol.
My MRT: http://www.cb7tuner.com/vbb/showthread.php?t=200048
(Turbo lag - turbo power) + HYPE = VTEC
Bought From: Davids92Accord
Sold To:
93Accordian is offline   Reply With Quote
Old 06-25-2013, 03:28 PM   #4
Clean_4th gen
Clean_4th gen is cool... so far.
Looks good. I love maroon CB7s.
1990 Accord EX
Clean_4th gen is offline   Reply With Quote
Old 06-26-2013, 11:43 AM   #5
oyajicool
oyajicool seems to have made some friends!
I wish I could find an Accord in that condition with that price or maybe lower.
A&P-IA
oyajicool is offline   Reply With Quote
Old 06-27-2013, 02:24 PM   #6
wildBill83
I have the wire harness out and the coolant system out of the way. I'm in Dallas for the weekend. I'll post photos this coming week.
Old 07-06-2013, 02:25 PM   #7
wildBill83
I'll post some photos up soon, I ran into some troubles and time issues. I hope to have the photos up later today.
It's looking like I need to replace the pass. side knuckle and axle because the PO destroyed the brass axle nut.
Please check my WTS/WTT thread in the classifieds if you have spare F22A1 parts.
Both this thread and the WTS/WTT thread will be updated shortly with photos.
All parts traded for will receive credit and a detailed write up for the community to share in my experience and maybe convince some folks to undertake a large mechanical restoration project or repair on their own.
Old 07-06-2013, 03:26 PM   #8
reklipz
reklipz seems to have made some friends! reklipz seems to have made some friends!
If you have access to a welder, you should be able to weld a rod onto that nut to spin it off. That way you can just buy a new nut and not a whole knuckle and axle.
reklipz is offline   Reply With Quote
Old 07-06-2013, 05:44 PM   #9
ferenza
ferenza seems to have made some friends! ferenza seems to have made some friends!
Im still wondering how you damage such a big nut
ferenza is offline   Reply With Quote
Old 07-07-2013, 11:34 PM   #10
wildBill83
Motor is out, look for photos in my motor removal thread once I'm not too lazy to upload them.
I'm debating on how to go about the manual to auto swap on this beast with the most OEM route. Either way it is going to sit under a tree as a shell while I replace seals on the motor and start to tear apart my SE and get it ready for the manual swap.
Old 07-09-2013, 06:21 PM   #11
wildBill83
Damaged axle nut:
I'm thinking a pissed off midget with a jack hammer stopped by to do maintenance on these axles.
Old 07-09-2013, 09:20 PM   #12
wildBill83
I think I got most of them listed now. My main concern is getting her pulled apart and gathering parts to complete her. I updated the first thread with the damages I have found so far.
Old 07-10-2013, 10:10 AM   #13
wildBill83
Since the motor is out, and I plan to do upgrades to the motor in the future, I'm adding an OEM oil cooler to the F22A1 block from my H22A4. Texas heat kills, and this summer is going to be hot!
Anyone know if the F22A1 has holes for a windage tray in the girdle? I wonder if my spare windage tray will bolt right up.... Hmmmm.
Old 07-10-2013, 10:53 AM   #14
Jarrett
It has provisions for it.
Old 07-10-2013, 01:32 PM   #15
wildBill83
Does this mean there are tapped holes or untapped holes? I'm planning to retrofit an H22 windage tray to the F22. Slight modifications might be needed I assume. I'll see when I get the motor taken apart in the next few days I'll know for sure.
Old 07-10-2013, 03:01 PM   #16
Jarrett
No, the holes are tapped. When I got my car the F22A6 had a thrown rod. I got Jeremiah's F22A1 and swapped ALL of my F22A6 parts over, including the windage tray. I left the main caps of the F22A1 intact and bolted the windage tray to it.
I'm also fairly sure that my H22A and F20B windage trays are identical to my F22A6. The only one I'm not sure of is my F23A windage tray. But that one's here in Houston with me so I can look tonight. Not that it really applies to you.
Old 07-10-2013, 03:31 PM   #17
wildBill83
As far as the short block goes, the windage tray and the oil cooler are the only differences between an F22A1 and F22A6 right? Also what are your opinions on the balance shafts anyway? The thought has crossed my mind to remove the BS belt and convert to manual steering and store the working Denso A/C components from the sedan. It is a fleeting thought though and generally passes when I think about cruising slowly in a parking lot with 100+F weather.
Would you happen to have a rear motor mount bracket (block side) for an A4/A6 motor to spare? The A1 M/T rear mount and bracket is, well, let's just say weak looking and not very forgiving. I would like to get an SE/EX rear mount bracket and pair it with the fluid filled non vacuum actuated EX M/T mount. The steering wheel in the LX vibrated worse than my SE with bad mounts.
Spare windage tray from an H22A4 I just cleaned the rust off of:
Oil cooler from H22A4 that I'm adding to the F22A1.
Old 07-10-2013, 07:13 PM   #18
2winRB25
2winRB25 is cool... so far.
LMK how the oil cooler off the H22A4 works on the F22Ax. Its possible I'd be interested in doing that if it fits well.
"Great spirits have always encountered violent opposition from mediocre minds." -Albert Einstein
2winRB25 is offline   Reply With Quote
Old 07-10-2013, 07:16 PM   #19
wildBill83
It fits like a glove, in fact the o-ring and the center bolt are even the same part number between the F22A6 and H22A*, I haven't checked the oil cooler itself for part number matches, but it is exactly the same size and shape as the one on my F22A6. I should have photos up soon, I have to do a lot of cleaning and work on my block before that though..
Be warned, if installed incorrectly it will be the biggest fastest oil leak you have ever seen!
Look here for oil cooler o-ring info:
http://www.cb7tuner.com/vbb/showthread.php?t=194757
The oil cooler is found only on A/T F22A6 accords, but I believe the H22A4 has is as mandatory equipment.
Old 07-10-2013, 07:29 PM   #20
2winRB25
Thank you! You are aware of my recent modifications to my A4. This should be a fun and cheap modification to finish it off. No A6s at the JY near me but there are two H22A4s.
