Old 08-05-2012, 01:56 PM   #1
wildBill83
wildBill83 seems to have made some friends!
wildBill83 : 1993 Accord SE
Well I saved this Coupe from being salvaged because I needed cheap reliable transport to my new job and my Ford just gave up the ghost. I got it for a few hundred dollars so I knew it was in poor shape to begin with but the motor was strong with 165K miles and the transmission was fine but needed a new TCU. The previous owner thought the tranny was shot and had awesome service records, but the car was externally abused and just didn't want to put more $$ into it. The pictures I'm about to post are not the prettiest on the forum, nor do I claim to have an amazing CB. I have literally only had this car for less than a week, and the laundry list of repairs has been a junk yard challenge.
Over all I have less than $800 in the car so far! EDIT: This is before modding and repairing...
Also it looks better when you look at it when drunk or through squinted eyes at a distance, the sad thing is that the coupe is 100% better now than it was when I first picked it up, and I still have a LONG way to go before I'm happy with the appearance of the car. So rather than starting with a mod list I'm starting with a repair list. As I have the car longer you will see where it goes and where it came from.
As it sits 11/03/2012:
Just after I joined:
More photos on page 3:
http://www.cb7tuner.com/vbb/showpost...7&postcount=49
REPAIR LIST (Completed)
Windshield replacement
Front end damage
Passenger side TBone damage
TCU repair with RadioShack parts and a spare TCU ordered from fleaBay just in case
Replace cracked sun roof (used 1990 Accord Sedan glass)
Replace Bose cassette head unit (LCD screen died on it the day I bought it)
Remove and bypass stock Bose Amp
Remove 6 disc CD changer
Replace worn Bose speakers
Replace shift lock solenoid
Replace Passenger door
Replace weather stripping on passenger door
Repair tan interior handles until I find replacements in junk yard
Oil drained, driven and then refilled twice
Tranny drained and refilled, driven, repeat 3x
O2 sensors to pass emissions
Replace power antenna with stationary from a civic for a temp fix
Replace oil pan gasket
Replace main seal
Replace timing belt
Tune-up
accesory/power steering belts
A/C rebuild and upgrade via thread on this forum
Tweak front end a bit more, she is close but no cigar you still tell it whacked something or someone hard at one point
Motor mounts
New valve cover gasket set (had oily plugs)
New oil cooler o-ring (fixed that damn leak on the back of the block)
driver axle
passenger axle
tie rods (inner and outer)
upper control arms
lower control arms
lower ball joint
hub/bearings in front
hub/bearings in rear
Distributor Cap
Distributor Rotor
Distributor ICM and o-ring
REPAIR LIST (Needs)
Repair then replace power antenna mast (damn thing is aftermarket)
Remove nasty dent from donor passenger door
body work and paint
Retint rear and quarter windows with limo tint and the front windows with 35%
MOD LIST
Acura PS cap
Acura Hood struts
Legend front lip
Sedan trunk swap w/ spoiler
ENGINE
STOCK F22A6
EXTERIOR
STOCK
Needs new hood and front panels
Still sourcing JY trim to comple OEM restoration
Will sand prime and block over the winter
INTERIOR
STOCK
New door handles from JC Whitney
All OEM parts located for restoration
SUSPENSION/WHEELS
H&R Lowering Springs
Koni Yellow Struts revalved for H&R spring drop
Kazera 16x7 rims
Hankook Ventus 205/55R16
Energy Suspension Poly bushings
AUDIO/ELECTRONICS
Pioneer Head Unit
Kenwood Speakers (front and rear)
Infinity Kappa 10" Subwoofer in MTX Bandpass box
Alpine MRX M100 mono amp
1.5farad capacitor
FUTURE PLANS
OEM Swaps of junkyard finds:
Integra front seats
BB6 gauge cluster
Fog lights and/or bumper swap
DOHC VTEC (H22A) engine swap(SOLD)
DOHC VTEC H22A4 engine rebuild and swap
H22A LSD Auto transmission
P13 OBD1 ECU
many more, will add as I think of it... I'm just getting started on this car after all!
GOALS
1. Reliable transport to work for the next 6 months (ACHIEVED!)
2. Get another reliable DD then garage, paint, and make an NA VTEC sleeper out of it that looks somewhere between JDM and stock but not riced out (no offense if body kits and huge wings are your thing, they just aren't mine)
wildBill83 is offline   Reply With Quote
Old 08-05-2012, 02:16 PM   #2
DarkHusk11
DarkHusk11 is cool... so far.
Nice se dude! cant wait to see what you do with it.
DarkHusk11 is offline   Reply With Quote
Old 08-05-2012, 02:33 PM   #3
Jarrett
Looks pretty good. '93 SE coupes are pretty neat cars.
Some recommendations:
If your antenna mast is broken but you still hear the motor when you turn the radio on then the $15 mast on eBay is all you need. It can be a lightly tricky install but once it's done it works 100% like OEM.
Door handles are another eBay item. It's extremely common for them to break and any good ones you find in the junkyard aren't far away from breaking themselves. New ones have been reinforced to not have that issue and I've had success with even the cheapest ones on eBay.
Also, if by "VTEC engine" you mean an F22B1, I'd strongly reconsider. Either way, if it's only the long-block you're going to need an intake manifold and header as well as the ECU to complete the swap. For the gains that it offers it's not worth it. For the potential it offers, it's a downgrade.
Car looks good and you seem to work pretty quickly. It will be nice to see what else is in store for it.
Old 08-05-2012, 03:20 PM   #4
wildBill83
Thanks! I originally wasn't going to do anything with it until I found this forum when searching for the Bose stereo info, then you guys got the best of me and I saw how nice these little Accords can be with all the swaps and such. That got my gears turning, now I'm hooked.
So your saying sell the H22A VTEC I have moth balled? I really want to finish the NA tune I started on it nearly 10 years ago for my Integra I totaled. I wouldn't put an F22B1 in because like you said it is more of a downgrade and could just turbo the stock motor for cheaper. I have a non-power antenna from a civic on the car now until I can replace the aftermarket mast that goes with the aftermarket power antenna the previous owner installed. I got a trunk full of bad parts right now I'm trying to figure out what to do with LOL. The stationary antenna works great, just have to move it out of the way when opening the trunk ... until I get an acura vigor flush spoiler, been eyeing the one in your for sale section very closely.
The key to working quickly is controlling my ADD and focusing on taking everything off, spreading it all out, then fixing what I see wrong then putting it all back on, takes too much time to fix one thing at a time. This irritates some people when earlier in the week it was one piece, then a million parts, then back to one.
That rattle can tan paint on the passenger door came out well in the photos too, that door was blue!
As far as the door handles go, I'll just JB Weld the ones I have and sand and rattle can paint tan I think. If I goop the JB Weld where it is the weakest maybe I can get away with repairing what I got and they will make it for a while. I have grey ones on the car now, but them not matching is driving me nuts. The original tan ones are about to be JB Welded tonight, maybe sanded and painted tomorrow.
Again, thanks for the warm welcome and words of encouragement!
Old 08-05-2012, 04:11 PM   #5
BIGRICH
Heywood Jablome
BIGRICH seems to have made some friends! BIGRICH seems to have made some friends!
not bad at all for <800 bucks.....the rattle can job isnt bad at all....could only see slight difference only after reading about it. good find
SHARPIE ACCORD HERE....
http://www.cb7tuner.com/vbb/showthread.php?t=192457
BIGRICH is offline   Reply With Quote
Old 08-05-2012, 04:28 PM   #6
wildBill83
Thank you BIGRICH
I have put a few hours in it already, you should have seen what it looked like before!
Old 08-05-2012, 04:30 PM   #7
BIGRICH
Heywood Jablome
Originally Posted by wildBill83 View Post
Thank you BIGRICH
no before pics available?
Old 08-05-2012, 04:30 PM   #8
Jarrett
No, if it's an H22A then hang on to it. By only saying "VTEC" to differentiate from what you currently have I thought you were referring to the F22B1.
Old 08-05-2012, 04:45 PM   #9
wildBill83
It might as well have looked like what was in a pick-n-pull lot before...
I was too embarrassed to even take photos before I messed with it or even drive it around town like that. The Craigslist add didn't even have photos it was in such bad shape. I wasted no time with photos before going to the junk yard and tearing it down and fixing her up... Still a long way to go yet.
I parked it in the shade so you can't see all the dents I pulled out from the body panels as well, a bit of light trickery!
Ha, just noticed my dog pissing next to the horse barn in the last photo... Good boy!
Old 08-06-2012, 11:07 AM   #10
keepinitclean
keepinitclean is cool... so far.
Very good start! An SE coupe! Do want I'd love to see more updates
KEEP IT NICE, NOT RICE
keepinitclean is offline   Reply With Quote
Old 08-06-2012, 12:01 PM   #11
slammed91cb7
slammed91cb7 may have said something they shouldn't have...
Send a message via AIM to slammed91cb7
not bad at all for 800,cant wait to see what else you do to it.
slammed91cb7 is offline   Reply With Quote
Old 08-06-2012, 01:16 PM   #12
wildBill83
Just got back from the junkyard empty handed ... damn what a waste of gas. Was hoping to find a vigor flush mount rear spoiler and a legened coupe lip but someone beat me to it. Also was going to try and score the digital A/C setup in a sedan I saw last time I was there but they already crushed it. So today I'm trying to bend some more metal back into place to correct the placement of the the lights, turn signals and front bumper, that gap is driving me nuts. Car is parked in front of a tree right now with the front end torn apart, taking a break from wrenching on the come-a-long I'm using to pull metal straight again and the rubber mallet I use to "massage" the bent parts too. It's hot out there folks, especially when your mad and swinging a mallet! Also I think while I got her torn apart may replace the serpentine belt, got the wrong one last week and have had a new one in the trunk since yesterday mingling with my bad parts I need to recycle or put in storage.
Well back to swinging the hammer and yanking on the body. I got a nasty dent on the donor door I need to remove the panel on the inside and tap out, should have done it when I put the new speakers in.
Old 08-07-2012, 12:25 AM   #13
crazymikey
crazymikey is very helpful crazymikey is very helpful
oooooh 93 SE coupe! Not a whole lot of those on here. These are pretty rare as far as CB7's go. They only made these in 1993 in the Champagne Silver colour you have, or in blue.....I beleive it's called Atlantis Blue.(Brittany Blue for the 91 SE sedan).
I like the plans you have for it, so I'm curious to see where it'll go from here.
crazymikey is offline   Reply With Quote
Old 08-07-2012, 01:52 AM   #14
Jarrett
If you saw a digital climate control in a CB7 then you would have had to have seen the JDM digital climate control or something custom. Just based on probability alone that's not very likely to see a JDM one because of the additional work required to get one functioning. Not something that would be too difficult for you, I presume.
Also, if the front end gives you any more trouble then you may want to have a go at this thread that TracieS did:
http://www.cb7tuner.com/vbb/showthread.php?t=185221
Old 08-11-2012, 10:41 AM   #15
wildBill83
Well the car is close for now, I'm now tinkering on this project:
Arduino Powered TCU Replacement
Old 08-19-2012, 09:21 AM   #16
wildBill83
Got a few things from the junkyard today:
Acura PSF cap with dip stick
Acura hydrolic hood arms
Acura legend sedan front lip
knobs and interior trim parts
16" rims and low profile tires (now I can use my 15" aluminum rims as winter rims tires are brand new on them)
cruise control module (didn't fix my problem)
and a few other small items here and there.
I'll post pics up once I get her lowered, she looks jacked up with the new shoes on, so much wheel well gap! I know what you will all say so I'm not showing it yet.
I have a new drier for the A/C in the mail (still trying to afford a new compressor)
New interior door handles in the mail
In the next few weeks I'll have a new radiator bracket (the big plastic one everything bolts to, not the ones on top)
New front quarter panels (maybe passenger door skin too)
New hood
New/used chrome trim (still need to find OEM replacement trim for passenger side)
I'll have it lowered at a shop so they can get my camber right, I don't have the tools to do this, but you can bet your bottom dollar I'll watch the mechanic like a hawk.
Old 08-19-2012, 07:10 PM   #17
crazymikey
You can do suspension yourself and drive it to an alignment shop.
If you don't get an adjustable camber kit, all the shop can do is adjust your toe in/out.
You can rent a spring compressor and just need jackstands and basic hand tools to re & re struts/springs.
Old 08-19-2012, 10:59 PM   #18
wildBill83
The nearest shop is a LONG drive over shitty roads, I'll bring in my CB7 with all the parts needed and just pay for their labor. I doubt they would let me do the suspension in the parking lot and I don't want to drive far with bad camber/alignment. I do plan to get everything for the shop to do it right and safely.
Old 08-19-2012, 11:13 PM   #19
wildBill83
Some small updates:
I got all of the last tan interior trim pieces today and picked up burgundy spares. I also replaced all of the interior light clear plastics. Interior is all stock and in decent shape now! I got my $2 worth at the junkyard today. BUT... I lost some bolts for my front bumper (I think the chickens ate them) and want a new metal backing for the bumper so back to the junk yard I go tomorrow, but not the Belton one, I picked it clean ... Elm Mott here I come.
Some updated photos (still not dropped the 2" I want to do yet so don't give me shit over ride height).
New rims next to rear rotors (got these for cheap with rubber and they are temporary, will sell them and get 17" later)
Stopped for a quick phone photo:
Finally got the front end straightened out from the previous owners wreck (still need to order new radiator backing bracket that supports lights and all as well as a new hood and drivers side quarter panel):
Anyone need a CB7 SE stock front lip? I'm putting an Acura Legend sedan lip on now. Will post photos when done.
Acura PSF cap with dip stick, these are SWEET!
Acura hood hydraulic mounting mock up:
More photos to come over time, I consider this a work in progress. Soon I'll be doing body work and prepping for paint (staying with stock color).
More photos with the bumper and new lip back on it tomorrow night and hopefully hood shocks.
Old 08-20-2012, 12:15 AM   #20
Jarrett
If I wasn't going to Chicago Wednesday I would say that you could come down here to Bryan and do the suspension in my driveway and then take it to an alignment shop. There's plenty here.
One suggestion for your car would be to tint your windows. That SE leather has a hard enough time staying together as it is. When the sun beats down on it it really doesn't stand a chance. Protect it with tint, even if it's just some 35% stuff.
Also, what are you going to use to lower it?
1993 se , wildbill83
