92 LX - I have intermittent dash display indicating a brake light out. But a check of the brake lights indicate that they are working properly. Is there a common loose connection/ground somewhere that I can fix? Thanks.
Brake light out indicator on but brake lights OK
Hello friend, welcome to the site
This is a common problem, there are brown and black "sensor" boxes mounted into the rear outer tail lamps and they tend to go bad, or at least have poor connections.
If you want to try restoring the functionality, make sure your tail light bulb sockets and related connectors are shiny and clean. It is common for the bulb sockets to get corroded, creating a false "disconnected" signal that the sensor box is incorrectly triggered by.
You can also try replacing the boxes, but the new ones you get might also be bad. If you know how to solder, you can open the boxes up and re-solder all of the connection points on the circuit board, because sometimes the original solder joints fail from heat and vibration over the years, causing the same "disconnected" signal.
If all else fails, there is a trick to bypass this circuit entirely to make the dashboard light stay OFF - you can see the simple wiring change in the picture below. This change is performed on the driver side outer tail lamp, at the brown box.
In case it isn't clear or the picture gets lost: you cut (or de-pin) the White/Green wire (white with a green stripe), and connect it - the harness side - to the Black ground wire.Last edited by cp[mike]; 12-09-2019, 04:36 PM.
Originally posted by underPSI View PostVerifying the correct wire is white w/ green stripe? I grounded that wire and no change. Any ideas what could be the issue?
The actual wire that you need to ground is WHITE with a GREEN STRIPE.
Some of the information suggested that it was a green wire with a white stripe, which is not true.
Make sure you grounded the correct one?
Originally posted by cp[mike] View PostYou just made me realize that my information listed above is misleading.
What's odd about mine is the black box is on the left side and brown is on the right. Both sides have a white w/ green stripe. I tried both sides independently without results. I've come to terms that I'm just going to have to remove the cluster and take out the bulb.
Originally posted by ly7244 View Post92 LX - I have intermittent dash display indicating a brake light out. But a check of the brake lights indicate that they are working properly. Is there a common loose connection/ground somewhere that I can fix? Thanks.
If you have water leaks around the tail lights, that can cause the issue as well.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Have you checked your brake fluid level and/or the fluid level sensor? It lights up the same dash light as the brake lights.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' Stephen Fry
Originally posted by underPSI View PostLow brake fluid level will illuminate the "brake lamp" light? Sure it's not the "brake" light?
BRAKE indicator at the top (in the cluster of indicators):
- parking brake is engaged, or
- brake fluid is low
BRAKE LAMP indicator at the bottom (in the little car door diagram):
- brake light is burnt out, or
- the sensor box (or the wiring) burnt out
the fix listed in this thread covers the BRAKE LAMP warning light.
