I have a 1993 honda accord 10th anniversary edition and about once in every 5 months or so it will stall but then like 30minutes later it will start up and run perfect again untill it stalls again. This problem is very annoying and just happens at random times. no its not the fact im stalling it because my car is an automatic. I read online and it said that it was the main (fuel) relay, so i did change that but today it happened again. I was just wondering if any of you reading this might know what it is or might have had the same problem. If you know what it is or think i should check something please let me know. Thanx
P.s. someone my dad works with has the same problem with a civic and he says someone told him that it probably the disstributor cap. When it stalls its like you lose all compression in the engine very quickly.
