Any "venting" is done through the EVAP system. Vapors are stored in the EVAP canister until they can be purged from the canister and burned in the engine.
I was reading about a valve on the on the tank of other accord models, I thought maybe ours had one?
the vent suction tube is connected from the tank up to the firewall, where it collects into the carbon filter canister. pretty sure the only valve is the EVAP purge solenoid valve that allows engine vacuum to clear out the canister.
