Old 03-13-2017, 12:43 PM   #1
masospaghetti
masospaghetti is cool... so far.
Am I in trouble? Installed head without locating pins
Are those dowel pins between the block and head an assembly aid, or are they really critical? Do the head bolts alone locate the head gasket sufficiently?
I had installed my head and put everything back together when the machine shop told me they had removed the dowel pins from the head and forgotten to give them back to me
I have them now in hand, but I would really rather not pull the head all over again unless its really necessary.
1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
Stock F22A6
VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
H23A1 powered
NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
masospaghetti is offline   Reply With Quote
Old 03-13-2017, 01:40 PM   #2
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
Absolutely pull the head. and definitely get a new headgasket.
I'd say you are pretty lucky they noticed and notified you.
Old 03-13-2017, 01:51 PM   #3
Rilas
I'd say pull the head as well. They do align it properly. If I remember correctly the head bolts actually go through the dowels.
Old 03-13-2017, 02:29 PM   #4
masospaghetti
Agreed, lucky they notified me.
Had this not been my first head remove/replace I might have noticed before I put everything together.
Just ordered another head gasket...
Stock F22A6
H23A1 powered
Old 03-13-2017, 10:07 PM   #5
F22Chris
100% pull the head. The head actually moves around on the block a little as it runs.
Old 03-13-2017, 10:47 PM   #6
fleetw00d
I did the opposite once. Just needed to replace the gasket, so I lifted the head (with manifolds and everything) enough to get the old gasket out and put the new one in. The dowels stayed with the head; I thought the previous owner might have left them out, so I installed two new ones, then tried to install the head - it won't sit right with two sets of dowels!
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 192,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 03-14-2017, 08:09 AM   #7
masospaghetti
Head is pulled, now just waiting on the gasket. At least the job is quicker the 2nd time.
Stock F22A6
H23A1 powered
Old 03-16-2017, 05:37 PM   #8
masospaghetti
Got my new head gasket today and it came in a package labeled "UNSALEABLE". There's a scratch on it between the cooling passage and cylinder opening deep enough to catch my finger. Needless to say I am not pleased.
I assume its a bad idea to re-use my old gasket? I started the engine but only briefly, it never got hot. It looks fine. Unfortunately the H23A1 is not that common and the gaskets are all special order.
Stock F22A6
H23A1 powered
Old 03-16-2017, 05:43 PM   #9
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
I see 2 concerns with reusing a headgasket, especially yours:
1. if anything was slightly out of alignment, it would have compressed the gasket in that pattern. Realigning and recompressing could create overlaps across areas that were or were not compressed before.
2. the black coating on either side often gets stuck to the block/head mating surface and you would lose this important coating in some spots, or possibly have double-thickness in others.
They are cheap enough and critical enough that I wouldn't mess with it. I've reused a headgasket in a stock F22 before, but I knew the alignment didn't change, and I actually applied a thin coating of copper sealant spray on both sides before installing it... I don't think that's the sort of level you should be going to.
Super lame about receiving clearly bad parts - heck it was even labeled as such... ridiculous. Some packer was sleeping that day.
