i recently bought a new battery after my old one started to spill battery acid..before changing my battery i was having the issue that my radio would randomly turn off after a while of driving.. then as time passed it got worse. My stereo and headlights would go out..and my idle would drop drastically to around 300. then my gauge cluster would turn off and then when i would turn my car off it wouldn't turn on.. i have a 3 day old battery and its still doing the same thing! any thoughts??
battery wont hold charge!
there's an easier way to go about all this.
parts stores can test your electrical system with one easy tool and tell you what your possibilities are. if the alternator is charging low, it'll tell you. If the test isn't clear, you can remove the alt and have it bench tested also.
all for free my friend.
Originally posted by No Name13 View Posti recently bought a new battery after my old one started to spill battery acid..before changing my battery i was having the issue that my radio would randomly turn off after a while of driving.. then as time passed it got worse. My stereo and headlights would go out..and my idle would drop drastically to around 300. then my gauge cluster would turn off and then when i would turn my car off it wouldn't turn on.. i have a 3 day old battery and its still doing the same thing! any thoughts??
From your description I'd agree with the above comments that you need to have your alternator tested.
While the engine is running, check the battery voltage and let us know what it reads
My 5.7 LS1 Holden Ute
You can get a useable volt/ohm meter for $10 these days. Your volt readings, at the battery posts with the car running, should be around 13.5 volts.
There are two connections coming from your battery positive post. One goes to your starter the other to the underhood fuse box. Check the latter cable and it's connections. The random loss of radio, lights. etc. points to a problem with this cable. Below is my repair/replacement.
Originally posted by ef9kidit seems to be your altenator..easy fix there should be 2 bolts on it.. if your near the maywood area in la i can help you out on this..
email me at cookiemonsters09@live.com
I took my alternator to go get checked out and the guy there looked at it for 10 seconds and said "its fucked" lol. He said he couldn't rebuild it because it was burnt out either due to jumpstarting the car allot or having allot of bass in my sound system (the alternator couldn't keep up with the power the amp needed and i'm running 2 10 inch subs..) either way i did both allot. Prior to getting a new battery, my old battery was spilling battery acid so the only way to get around was to get a jump start.
lesson learned! Dont have so much bass if you don't have one of those capacitor things.
Also..some of you told me to remove the POS cable from the battery as the car is running...the guy at the shop said that most alternators mess up after that..something about the alternator producing a steady 14V and when you disconnect the POS from the battery the voltage regulator in the alternator heats up and burns out.
thanks for all your help!
Invest in a multi-meter.
The way to check if your charging system is working properly is by checking battery voltage with the car off, it should read about 12.4 volts. With the car running check battery voltage and it should be between 13.8 to 14.4 volts anything below 13 means your alternator needs to be replaced. To test the battery charge fully it using a A/C charger so you don't overstress your alternator then let it sit for a few, connect your multi-meter and check voltage it reads below 12 volts you need to have the battery replaced.Last edited by ssondubs; 08-08-2011, 01:05 AM.1993 Accord LX Coupe 5spd
