I've been eyeing these for a while, I just cant wait to get one, especially now that there's this nice easy to follow DIY.
INT : P12 Install
Originally posted by visualpoet View PostI see you have a five speed. lol When I swapped my pt3 for the p12, I wondered what the automatic owners will do. The way it sits in there, it seems like the TCU will be in the way. (and yours is backwards, plugs go towards the console. I know it's just to demonstrate, but someone will say "I can't get mine in there the way you showed it. The harnesses are too short.")
I wrapped silicone tubing around my p12 a few times to keep it from vibrating or banging around under there. It also helps keep it from sliding back and forth and weakening the connections.
I know the p12 is supposed to be ten ponies, but, using my Beltronix accelerometer (it figures HP based on vehicle weight vs 1/4 mile time and trap speed) I showed a fifteen HP increase. I think the I/H helped it out a little. I went from a best of 17.4 @ 78.4 mph in the 1/4 to 16.7 @ 81.6 mph in a 3150 lb car with me and the ICE in it. 118 hp to 133 hp isn't bad for $58 shipped. I've got a full 60mm exhaust on it now, but no numbers to compare.
Just wondering, where did you find the ecu for $58? The cheapest one that I could find was closer to $120. Just curious. Thanks
Time is money...
I have a 92 Accord LX, F22A1 with an automatic transmission. Which P12 do I need to use. From what I read above, any P12 should work. Is this correct? I just want to make sure before I take the plunge and invest $ into an ECU. I'm pretty new to the Accords. I know on the Integras, the ECUs are different depending on the transmission that the car has. Do all CB7s with the same motors use the same ECU regardless of the transmission? And if so, is this because of the TCU? Thanks...
Originally posted by insanity8797 View PostI have a 92 Accord LX, F22A1 with an automatic transmission. Which P12 do I need to use. From what I read above, any P12 should work. Is this correct? I just want to make sure before I take the plunge and invest $ into an ECU. I'm pretty new to the Accords. I know on the Integras, the ECUs are different depending on the transmission that the car has. Do all CB7s with the same motors use the same ECU regardless of the transmission? And if so, is this because of the TCU? Thanks...wat?
